Re: how to case match without cracking the engine
SABAT! andDestroy /
paraffin wax, im a strong beleiver that works the best for a few good reasons.
-its a lubricant, Good for initinal start-up and break in
- makes a water-tight seal of the crankcase, easy to blast all the shavings out with a water hose
- creates a good smell of victory when you start up.
- holds the con rod steady.
-removes carbon biuld ups
basically drop the motor and get the crankcase exposed(15 min)
fill it full of wax by melting it in, port-match, blast it out with water, heat up the case facing down, and turn the flywheel until you can get a full rotation (this also helps clear any shavings left behind) then bolt it all together a start it up, any wax left behind will vaporize and exit as a vapor.
  how to case match without cracking the engine caseTopic by: Ian Ian 01/02/10 03:09PM
  Re: how to case match without cracking the engineRe: GARzan Justin GARzan Justin 01/02/10 03:13PM
  Re: how to case match without cracking the engineRe: SABAT! andDestroy SABAT! andDestroy 01/02/10 03:38PM
  Re: how to case match without cracking the engineRe: Ian Ian 01/02/10 03:47PM
  Re: how to case match without cracking the engineRe: Sunset Paul Sunset Paul 01/02/10 03:55PM
  Re: how to case match without cracking the engineRe: mit mortso mit mortso 01/02/10 04:00PM
  Re: how to case match without cracking the engineRe: SABAT! andDestroy SABAT! andDestroy 01/02/10 04:03PM
  Re: how to case match without cracking the engineRe: rofman rofman 01/02/10 04:14PM
  Re: how to case match without cracking the engineRe: Flagrant - Flagrant - 01/02/10 04:14PM
  Re: how to case match without cracking the engineRe: Tom STL Tom STL 01/02/10 04:23PM
  Re: how to case match without cracking the engineRe: Josh G Josh G 01/02/10 04:39PM
  Re: how to case match without cracking the engineRe: Kansas John Kansas John 01/02/10 04:59PM
  Re: how to case match without cracking the engineRe: Ian Ian 01/02/10 05:10PM
  Re: how to case match without cracking the engineRe: joshua joshua 01/02/10 05:17PM
  Re: how to case match without cracking the engineRe: Tom STL Tom STL 01/02/10 05:18PM
  Re: how to case match without cracking the engineRe: the worst terry the worst terry 01/02/10 05:24PM
  Re: how to case match without cracking the engineRe: Patrick Lowery Patrick Lowery 01/02/10 05:34PM
  Re: how to case match without cracking the engineRe: CtpEDsHED . CtpEDsHED . 01/02/10 08:17PM
  Re: how to case match without cracking the engineRe: Gabe Bandit Gabe Bandit 01/02/10 08:45PM
  Re: how to case match without cracking the engineRe: peter peter 01/02/10 09:08PM
  Re: how to case match without cracking the engineRe: fishstics fishstics 01/02/10 09:29PM
  Re: how to case match without cracking the engineRe: jack jack 01/03/10 02:26AM
  Re: how to case match without cracking the engineRe: -Brian- The Ruffians STL -Brian- The Ruffians STL 01/06/10 04:29PM
  Re: how to case match without cracking the engineRe: Josh G Josh G 01/06/10 08:31PM
  Re: how to case match without cracking the engineRe: Jon Jon 01/13/10 02:17AM
  Re: how to case match without cracking the engineRe: Jaym Jaym 01/13/10 02:59AM
  Re: how to case match without cracking the engineRe: Organ Robbin' Organ Robbin' 01/13/10 10:53AM
  Re: how to case match without cracking the engineRe: - Summerai - Christine L - Summerai - Christine L 01/13/10 11:47AM
  Re: how to case match without cracking the engineRe: Mo Peds Mo Peds 01/13/10 12:51PM
  Re: how to case match without cracking the engineRe: MikeGeez MikeGeez 01/13/10 01:24PM
  Re: how to case match without cracking the engineRe: rock finally shredding pow rock finally shredding pow 01/13/10 01:33PM
  Re: how to case match without cracking the engineRe: - Summerai - Christine L - Summerai - Christine L 01/13/10 02:49PM
  Re: how to case match without cracking the engineRe: Ian Ian 01/13/10 03:36PM
  Re: how to case match without cracking the engineRe: mauvescorpion mauvescorpion 01/13/10 03:50PM
Want to reply to this thread?
