Re: connecting/charging batteries in parallel
Flagrant - /
There is no problem with this. You can recharge both at the same time or seperately as long as the batt charger can maintain one or two volts over the batt voltage. Lesser voltage will charge the batts up but not to full charge.
Click here to login.
