Re: Best Engine Tensioning Spring Setup For Rigid
Tommy Too Tall /
Yea the doppler one mounts up to the case through a case bolt, the back has one hole for mounting to the swingarm. A rigid has a hole in generally the same place on the piece of metal between the wheel supports, I doubt it would be a direct fit, but it is probably a good start.
A slightly shorter belt should help with it slipping too, although belt slip can be a desirable thing if you want your bike to take off like a rocket, ninja secret of fast french.
Click here to login.
