Re: upjet??
Geoff /
Is there a way to tell by the way it idles at all? Cause mine seems to need to be at a higher rpm to keep from stalling... I cleaned the carb and airfilter and even put a clean foamie thing in the biturbo exhaust. I then adjusted themixture screw per wiki directions. It seems to idle fine for a minute or so then slowly drop rpms until it stalls:( if I turn up the idle by turning the idle screw in it seems too high rpm, and any lower it goes for a minute then stalls. Ugh
Want to reply to this thread?
