upjet??
Geoff /
So, you all have helped me learn sooo much about my Tomos!! I successfully fixed the throttle assembly, installed new throttle cable, adjusted chain, and cleaned out the carb :)
I have searched hi and low on the forum and cant really get clarification so I'm sorry if this is a dumb question, but I'm still learning....
While cleaning out the carb, I noticed the jet size.. I have a 70 cc kit from Heeters that came with a 15mm Amal carb running a 45 jet.. It seems to run ok after I cleaned out the carb but idle still seems a wee bit eratic.. I adjusted the idle and mix screws thanks to wiki... just wondering...
Want to reply to this thread?
