Re: poortmap
[[ Linda ]] /
I dunno, A35's are much more complicated than E50's. I wouldn't recommend cracking the case unless something was FUBARed you were SURE that you would solve things that way.
On my A3 at least, (and I believe that A35s fall under the same principle) you can replace the seals without cracking the case. You have to take the clutch cover and clutches off, but that's not that hard. It's kind of a moot point though, because if your crank seal was bad, you'd be burning transmission fluid, and there would be copious amount of white smoke coming out of the exhaust. If you aren't seeing abnormal amounts of smoke, then your seals are probably fine. Another sign of burning transmission fluid is if you refill it to the proper amount, then check it later and find you have significantly less fluid than you started with, but you know it hasn't been making leaky transmission puddle fluids on the ground.
  poortmapTopic by: charHARHARHARlie charHARHARHARlie 12/28/09 11:59PM
  Re: poortmapRe: fishstics fishstics 12/29/09 07:48PM
  Re: poortmapRe: Better Fส็็็็็็็็็็็็็็็็ster Better Fส็็็็็็็็็็็็็็็็ster 12/29/09 09:29PM
  Re: poortmapRe: GARzan Justin GARzan Justin 12/29/09 10:06PM
  Re: poortmapRe: GARzan Justin GARzan Justin 12/29/09 10:10PM
  Re: poortmapRe: Better Fส็็็็็็็็็็็็็็็็ster Better Fส็็็็็็็็็็็็็็็็ster 12/29/09 10:15PM
  Re: poortmapRe: GARzan Justin GARzan Justin 12/29/09 10:41PM
  Re: poortmapRe: charHARHARHARlie charHARHARHARlie 12/30/09 09:17AM
  Re: poortmapRe: Austin Austin 12/30/09 12:59PM
  Re: poortmapRe: charHARHARHARlie charHARHARHARlie 12/30/09 10:23PM
  Re: poortmapRe: GARzan Justin GARzan Justin 12/30/09 11:46PM
  Re: poortmapRe: charHARHARHARlie charHARHARHARlie 12/31/09 12:31AM
  Re: poortmapRe: Better Fส็็็็็็็็็็็็็็็็ster Better Fส็็็็็็็็็็็็็็็็ster 12/31/09 01:57AM
  Re: poortmapRe: charHARHARHARlie charHARHARHARlie 12/31/09 03:28AM
  Re: poortmapRe: charHARHARHARlie charHARHARHARlie 12/31/09 03:47AM
  Re: poortmapRe: charHARHARHARlie charHARHARHARlie 12/31/09 03:35PM
  Re: poortmapRe: seank seank 12/31/09 08:28PM
  Re: poortmapRe: GARzan Justin GARzan Justin 12/31/09 08:34PM
  Re: poortmapRe: charHARHARHARlie charHARHARHARlie 01/02/10 06:36AM
  Re: poortmapRe: GARzan Justin GARzan Justin 01/02/10 03:21PM
  Re: poortmapRe: [[ Linda ]] [[ Linda ]] 01/03/10 12:05AM
  Re: poortmapRe: charHARHARHARlie charHARHARHARlie 01/03/10 06:51AM
  Re: poortmapRe: charHARHARHARlie charHARHARHARlie 01/03/10 06:59AM
  Re: poortmapRe: Mo Peds Mo Peds 01/03/10 10:50AM
  Re: poortmapRe: Mo Peds Mo Peds 01/03/10 11:05AM
  Re: poortmapRe: GARzan Justin GARzan Justin 01/03/10 01:16PM
  Re: poortmapRe: [[ Linda ]] [[ Linda ]] 01/03/10 04:21PM
  Re: poortmapRe: charHARHARHARlie charHARHARHARlie 01/03/10 05:46PM
  Re: poortmapRe: charHARHARHARlie charHARHARHARlie 01/03/10 05:53PM
  Re: poortmapRe: GARzan Justin GARzan Justin 01/03/10 06:24PM
  Re: poortmapRe: charHARHARHARlie charHARHARHARlie 01/03/10 07:17PM
  Re: poortmapRe: charHARHARHARlie charHARHARHARlie 01/03/10 08:25PM
  Re: poortmapRe: GARzan Justin GARzan Justin 01/03/10 08:49PM
  Re: poortmapRe: charHARHARHARlie charHARHARHARlie 01/03/10 09:44PM
  Re: poortmapRe: charHARHARHARlie charHARHARHARlie 01/03/10 11:06PM
  Re: poortmapRe: GARzan Justin GARzan Justin 01/04/10 12:33AM
  Re: poortmapRe: Graham Motzing Graham Motzing 01/04/10 11:14PM
Click here to login.
