Re: poortmap
GARzan Justin /
^What's that for? He made a great port map.
It probably is the rust from your tank making your plug red. Do you have an in-line fuel filter?
You need a colder plug if there's any evidence of pinging, you need a warmer plug if you're always fouling your plug. I run the coldest plug I can without fouling; I've ran a B9HS and never fouled it. Timing should generally be okay at the stock setting. You might get away with advancing it a bit, that will give you more low-end at the cost of higher cylinder temperatures.
If I were you, I'd just crack the case open and check everything. Replace the seals and bearings as soon as you can afford it, it'll save you a lot of headache later on. I'd replace the crank when you replace the seals. Treats has a great Tomos performance crank
  poortmapTopic by: charHARHARHARlie charHARHARHARlie 12/28/09 11:59PM
  Re: poortmapRe: fishstics fishstics 12/29/09 07:48PM
  Re: poortmapRe: Better Fส็็็็็็็็็็็็็็็็ster Better Fส็็็็็็็็็็็็็็็็ster 12/29/09 09:29PM
  Re: poortmapRe: GARzan Justin GARzan Justin 12/29/09 10:06PM
  Re: poortmapRe: GARzan Justin GARzan Justin 12/29/09 10:10PM
  Re: poortmapRe: Better Fส็็็็็็็็็็็็็็็็ster Better Fส็็็็็็็็็็็็็็็็ster 12/29/09 10:15PM
  Re: poortmapRe: GARzan Justin GARzan Justin 12/29/09 10:41PM
  Re: poortmapRe: charHARHARHARlie charHARHARHARlie 12/30/09 09:17AM
  Re: poortmapRe: Austin Austin 12/30/09 12:59PM
  Re: poortmapRe: charHARHARHARlie charHARHARHARlie 12/30/09 10:23PM
  Re: poortmapRe: GARzan Justin GARzan Justin 12/30/09 11:46PM
  Re: poortmapRe: charHARHARHARlie charHARHARHARlie 12/31/09 12:31AM
  Re: poortmapRe: Better Fส็็็็็็็็็็็็็็็็ster Better Fส็็็็็็็็็็็็็็็็ster 12/31/09 01:57AM
  Re: poortmapRe: charHARHARHARlie charHARHARHARlie 12/31/09 03:28AM
  Re: poortmapRe: charHARHARHARlie charHARHARHARlie 12/31/09 03:47AM
  Re: poortmapRe: charHARHARHARlie charHARHARHARlie 12/31/09 03:35PM
  Re: poortmapRe: seank seank 12/31/09 08:28PM
  Re: poortmapRe: GARzan Justin GARzan Justin 12/31/09 08:34PM
  Re: poortmapRe: charHARHARHARlie charHARHARHARlie 01/02/10 06:36AM
  Re: poortmapRe: GARzan Justin GARzan Justin 01/02/10 03:21PM
  Re: poortmapRe: [[ Linda ]] [[ Linda ]] 01/03/10 12:05AM
  Re: poortmapRe: charHARHARHARlie charHARHARHARlie 01/03/10 06:51AM
  Re: poortmapRe: charHARHARHARlie charHARHARHARlie 01/03/10 06:59AM
  Re: poortmapRe: Mo Peds Mo Peds 01/03/10 10:50AM
  Re: poortmapRe: Mo Peds Mo Peds 01/03/10 11:05AM
  Re: poortmapRe: GARzan Justin GARzan Justin 01/03/10 01:16PM
  Re: poortmapRe: [[ Linda ]] [[ Linda ]] 01/03/10 04:21PM
  Re: poortmapRe: charHARHARHARlie charHARHARHARlie 01/03/10 05:46PM
  Re: poortmapRe: charHARHARHARlie charHARHARHARlie 01/03/10 05:53PM
  Re: poortmapRe: GARzan Justin GARzan Justin 01/03/10 06:24PM
  Re: poortmapRe: charHARHARHARlie charHARHARHARlie 01/03/10 07:17PM
  Re: poortmapRe: charHARHARHARlie charHARHARHARlie 01/03/10 08:25PM
  Re: poortmapRe: GARzan Justin GARzan Justin 01/03/10 08:49PM
  Re: poortmapRe: charHARHARHARlie charHARHARHARlie 01/03/10 09:44PM
  Re: poortmapRe: charHARHARHARlie charHARHARHARlie 01/03/10 11:06PM
  Re: poortmapRe: GARzan Justin GARzan Justin 01/04/10 12:33AM
  Re: poortmapRe: Graham Motzing Graham Motzing 01/04/10 11:14PM
Want to reply to this thread?
