Re: poortmap
GARzan Justin /
You _can_ go closer to the head on the intake side; reason being that you can raise the intake port to the point that it doesn't interfere with the ring, and this will effectively increase your port size/flow without altering duration, or making it wide enough to worry about snagging the piston. I do this to all of my cylinders.
I agree, cut your piston skirt 2-3mm; since you've got reeds, intake duration isn't as critical as on a piston-port kit. This is a Tomos Airsal, yeah?
That looks like a good starting point for a mild port job. Do that, do it well, chamfer the ports, and run it for about a week to think about what you want to do differently. Have fun with it!
  poortmapTopic by: charHARHARHARlie charHARHARHARlie 12/28/09 11:59PM
  Re: poortmapRe: fishstics fishstics 12/29/09 07:48PM
  Re: poortmapRe: Better Fส็็็็็็็็็็็็็็็็ster Better Fส็็็็็็็็็็็็็็็็ster 12/29/09 09:29PM
  Re: poortmapRe: GARzan Justin GARzan Justin 12/29/09 10:06PM
  Re: poortmapRe: GARzan Justin GARzan Justin 12/29/09 10:10PM
  Re: poortmapRe: Better Fส็็็็็็็็็็็็็็็็ster Better Fส็็็็็็็็็็็็็็็็ster 12/29/09 10:15PM
  Re: poortmapRe: GARzan Justin GARzan Justin 12/29/09 10:41PM
  Re: poortmapRe: charHARHARHARlie charHARHARHARlie 12/30/09 09:17AM
  Re: poortmapRe: Austin Austin 12/30/09 12:59PM
  Re: poortmapRe: charHARHARHARlie charHARHARHARlie 12/30/09 10:23PM
  Re: poortmapRe: GARzan Justin GARzan Justin 12/30/09 11:46PM
  Re: poortmapRe: charHARHARHARlie charHARHARHARlie 12/31/09 12:31AM
  Re: poortmapRe: Better Fส็็็็็็็็็็็็็็็็ster Better Fส็็็็็็็็็็็็็็็็ster 12/31/09 01:57AM
  Re: poortmapRe: charHARHARHARlie charHARHARHARlie 12/31/09 03:28AM
  Re: poortmapRe: charHARHARHARlie charHARHARHARlie 12/31/09 03:47AM
  Re: poortmapRe: charHARHARHARlie charHARHARHARlie 12/31/09 03:35PM
  Re: poortmapRe: seank seank 12/31/09 08:28PM
  Re: poortmapRe: GARzan Justin GARzan Justin 12/31/09 08:34PM
  Re: poortmapRe: charHARHARHARlie charHARHARHARlie 01/02/10 06:36AM
  Re: poortmapRe: GARzan Justin GARzan Justin 01/02/10 03:21PM
  Re: poortmapRe: [[ Linda ]] [[ Linda ]] 01/03/10 12:05AM
  Re: poortmapRe: charHARHARHARlie charHARHARHARlie 01/03/10 06:51AM
  Re: poortmapRe: charHARHARHARlie charHARHARHARlie 01/03/10 06:59AM
  Re: poortmapRe: Mo Peds Mo Peds 01/03/10 10:50AM
  Re: poortmapRe: Mo Peds Mo Peds 01/03/10 11:05AM
  Re: poortmapRe: GARzan Justin GARzan Justin 01/03/10 01:16PM
  Re: poortmapRe: [[ Linda ]] [[ Linda ]] 01/03/10 04:21PM
  Re: poortmapRe: charHARHARHARlie charHARHARHARlie 01/03/10 05:46PM
  Re: poortmapRe: charHARHARHARlie charHARHARHARlie 01/03/10 05:53PM
  Re: poortmapRe: GARzan Justin GARzan Justin 01/03/10 06:24PM
  Re: poortmapRe: charHARHARHARlie charHARHARHARlie 01/03/10 07:17PM
  Re: poortmapRe: charHARHARHARlie charHARHARHARlie 01/03/10 08:25PM
  Re: poortmapRe: GARzan Justin GARzan Justin 01/03/10 08:49PM
  Re: poortmapRe: charHARHARHARlie charHARHARHARlie 01/03/10 09:44PM
  Re: poortmapRe: charHARHARHARlie charHARHARHARlie 01/03/10 11:06PM
  Re: poortmapRe: GARzan Justin GARzan Justin 01/04/10 12:33AM
  Re: poortmapRe: Graham Motzing Graham Motzing 01/04/10 11:14PM
Want to reply to this thread?
