boggggggin
charharharharlie /
i just repacked my baffle on my estoril with some household insulation cuz the stuff in there looked like charcoal. it ran good for low end and seemed quieter but now when i hit 35ish it bogs like a beast. i was able to hit 50 before so why is the boggage so dramatic? i dont really have anywhere to do plug chops but from normal riding my plug looks the right color(coffee brown). the bogging sounds like when you cut the engine while riding and then give it throttle ifyanadadamean. it jerks a lot when it bogs like it wants to go but cant. its an a35 w/airsol kit and hicomp head and 16/16sha w/k&n style airfilter 79 jet
Re: boggggggin
50 with an estoril, no way.
Re: boggggggin
charharharharlie /
yes way, i thought it was impossible too but idk maybe i got a magic estoril.. it wasnt gpsd tho it was on one of those street speed things and it was on flat!
pls help my bog issue tho
Re: boggggggin
Probably Fred /
I run estoril on 2 polini powered puchs I go 51-53mph on the flat no tuck in the wind. you probably over packed the silencer. on your tomos with 16mm carb and 70cc- 50-55mph with a estoril is no problem
Re: boggggggin
estorils do not go that fast. sorry.
Re: boggggggin
I have an estoril..GPS'ed 51mph. lulz at that.
Re: boggggggin
lolercopter
Re: boggggggin
Probably Fred /
Look man If you can't go 50+ with a estoril that is ok try another pipe. Back in the old days I got 50mph out of a modded magnum pipe. I get 50+ mph out of a techno circuit pipe also
Re: boggggggin
charharharharlie /
ok ok its possible to go 50+ on an estoril, help me with my problem!! can repacking a baffle make you bog??
Re: boggggggin
charharharharlie /
oh ya and i cleaned out that thing with the holes in it cuz the holes were all clogged up
Re: boggggggin
Take the new material out and run it to see if that makes a difference..
Re: boggggggin
charharharharlie /
ok so i rode just now with it and without it..
with it i was able to hit high 40s again but the bog creeped up on me as the motor heated up, it wasnt as bad tho(bog every once in a while) but this is at night and its a hellovalot colder than it was when i was beastily boggin so is it possible that i need to downjet? but my plug is the correct color, wtf.
without the material i noticed waayyy better acceleration and minimal bogging, but again this is at night so i will test during the day and update.
does baffle packing make that much of a difference?
Re: boggggggin
you mite need to up jet
Re: boggggggin
charharharharlie /
ok ill try but the next jet up i have is an 82.. why is it that i would have to upjet?
Re: boggggggin
lolz. when i see an estoril go 50 i will pay someone 100 dollars.
Re: boggggggin
Get your head checked..life exists outside your little world.
Re: boggggggin
You say your plug is the right color ... you are using a new plug each time before you check it, right?
Re: boggggggin
Re: boggggggin
the pipe still blows dicks and i do not reccomend it
Re: boggggggin
but he owes you a hundred bucks, you can use that to get a better pipe!
Re: boggggggin
lol
pay up! $$$$
my estoril does 50 on my puch
Re: boggggggin
my estoril on my arrow R ran a 55......
