Re: Vespa engine cases
and you dont need to move the studs, performance cylinders have boost ports, just model it after that.
also make sure your exhaust port is squareish. at the max width you use more area if you cut out those corners.
  Vespa engine casesTopic by: Graham Motzing Graham Motzing 12/09/09 12:11PM
  Re: Vespa engine casesRe: Sunset Paul Sunset Paul 12/09/09 12:21PM
  Re: Vespa engine casesRe: Sam Blk Sam Blk 12/09/09 12:30PM
  Re: Vespa engine casesRe: Organ Robbin' Organ Robbin' 12/09/09 12:48PM
  Re: Vespa engine casesRe: maciek maciek 12/09/09 07:33PM
  Re: Vespa engine casesRe: Graham Motzing Graham Motzing 12/09/09 09:15PM
  Re: Vespa engine casesRe: Maitland Of the Loin Maitland Of the Loin 12/10/09 03:15AM
  Re: Vespa engine casesRe: Graham Motzing Graham Motzing 12/10/09 01:06PM
  Re: Vespa engine casesRe: Organ Robbin' Organ Robbin' 12/10/09 01:09PM
  Re: Vespa engine casesRe: Graham Motzing Graham Motzing 12/10/09 03:00PM
  Re: Vespa engine casesRe: Sunset Paul Sunset Paul 12/10/09 03:18PM
  Re: Vespa engine casesRe: Organ Robbin' Organ Robbin' 12/10/09 03:27PM
  Re: Vespa engine casesRe: Graham Motzing Graham Motzing 12/10/09 04:39PM
  Re: Vespa engine casesRe: Organ Robbin' Organ Robbin' 12/10/09 04:40PM
  Re: Vespa engine casesRe: Josh G Josh G 12/10/09 08:49PM
  Re: Vespa engine casesRe: Graham Motzing Graham Motzing 12/11/09 12:19PM
  Re: Vespa engine casesRe: Graham Motzing Graham Motzing 12/14/09 08:17PM
  Re: Vespa engine casesRe: Sunset Paul Sunset Paul 12/14/09 08:50PM
  Re: Vespa engine casesRe: Graham Motzing Graham Motzing 12/15/09 12:09PM
  Re: Vespa engine casesRe: Sunset Paul Sunset Paul 12/15/09 03:56PM
  Re: Vespa engine casesRe: Graham Motzing Graham Motzing 12/15/09 06:32PM
  Re: Vespa engine casesRe: jason w jason w 12/15/09 08:30PM
  Re: Vespa engine casesRe: Graham Motzing Graham Motzing 12/15/09 09:24PM
  Re: Vespa engine casesRe: Graham Motzing Graham Motzing 12/15/09 11:20PM
  Re: Vespa engine casesRe: Jason W Jason W 12/16/09 01:55AM
  Re: Vespa engine casesRe: Graham Motzing Graham Motzing 12/18/09 10:57AM
  Re: Vespa engine casesRe: Jason W Jason W 12/18/09 12:59PM
  Re: Vespa engine casesRe: Sunset Paul Sunset Paul 12/18/09 04:53PM
  Re: Vespa engine casesRe: Graham Motzing Graham Motzing 12/23/09 10:36AM
  Re: Vespa engine casesRe: Graham Motzing Graham Motzing 12/26/09 01:35PM
  Re: Vespa engine casesRe: Graham Motzing Graham Motzing 12/28/09 02:52PM
  Re: Vespa engine casesRe: Graham Motzing Graham Motzing 01/04/10 11:19PM
  Re: Vespa engine casesRe: James G James G 01/05/10 12:42AM
  Re: Vespa engine casesRe: Graham Motzing Graham Motzing 01/05/10 03:43PM
  Re: Vespa engine casesRe: Organ Robbin' Organ Robbin' 01/05/10 03:54PM
  Re: Vespa engine casesRe: Graham Motzing Graham Motzing 01/05/10 04:29PM
  Re: Vespa engine casesRe: Organ Robbin' Organ Robbin' 01/05/10 04:38PM
  Re: Vespa engine casesRe: jens jens 01/05/10 04:48PM
  Re: Vespa engine casesRe: jens jens 01/05/10 05:00PM
  Re: Vespa engine casesRe: Graham Motzing Graham Motzing 01/05/10 05:13PM
Click here to login.
