my magnum is bogging down. any help?
Jordan Nichols /
I used to be able to just full throttle and she would take off fine and switch gears smooth and with haste. Now she slows down before it kicks into second and i have to slow apply throttle to get slight acceleration. Any ideas of what i need to tinker with? I'd appreciate any help.
Re: my magnum is bogging down. any help?
Probably Fred /
Take apart the carb and clean every ( and learn to do this in your sleep) part in it. Take apart the petcock and fuel line clean or replace it check for leaks in intake and gaskets. clean and check and gap points.( you inspected and cleaned and gaped them when you got your bike right ?) know how to check timing. clean gap and change plug ect. If you can't do these things pay a moped or motorcycle shop to do them for you. If is not a engine bogging power loss problem it could be clutches. If it is not shifting ( its full of tranny fluid right ?) correctly then good luck- that would cost hundreds to fix
Bumpity Bump!!
