70kstar, e50, proma circuit, 14 sha.
its ok putting on cdi to see if it will really let it wind out.
what kind of mileage will i get?
sha? you loser.
you are contradicting hours of arguement for mileage. I don't even know you anymore. You are going to have to surrender your "blasto" title and trade it for "loser-0"
its questionable if he even deserves the cuper title too. i'd make him move. not here tho. ok, maybe.
blaster set up if tuned properly....
you don't want him benji, he's too far gone.
it might go alright, but it will never "blast"
it's been a while since justine has blasted. there is a 14.14 dellorto carb at the shop which was senda's stock carb. sure to "blast" the SHA. Want to ride this weekend and get super blasted justine/zack?
Zackie-poo - Chinese fighter pilot helmet acquired ;)
cool! Want to ride friday evening? I'm going to try to get LTD done (finally!?!), if not, then there's chap-master or magnumx. I'm probably gonna head back to berkeley later at night friday. I'll call you tomorrow evening when i arrive.
timed this yesterday, runs pretty good aside from scary metal-icky noises
by timed this do you mean took the stator off, dremmeled the holes, then rotated for full advance? Thats what I do.
metal icky as in scary bad? i know with the old tccd's you had to have a few extra base gaskets so that the piston wouldnt tap the head. though thats assuming the kstar has the same problem, which im not sure of.
lolz. you guys suck. ima blast you in your face.
the scary noise i think is coming from the clutch side. Whatev's ima just blast till it blows up.
i only got it to like 1.3/4. ima wait till i get a proper carb on there to super blast.
its such a big difference with the crappy sha. No acceleration and no serious blasting powerband.
you cuperteens better get yer act together.
k-stars sound scary as hell during "break-in"
as though you have to break in a k-star
proper ring gap?
blown bearing? Clutch not setup right? I'll tell you tonight/tomorrow.
i hope my bearing is not blown up. it might be. no atf, now a big atf leak.
im fucked.
i set the ring gap so thats ok, and its not a new kit. i need the clutch to slip lots more, so its just all the time full throttle.
you are never going to get the proper power with that small carb to get the kind of clutch slop you want. You gotta go bigger.
I doubt the bearing is bad, I'd guess one of the clutch circlips is loose or fell, so its all rattle-y.
ooooooohhh, thats why i had an extra circlip.. lolz
newb. what are you guys doing tonight? I'll be home around 8. Give me a call later.
You guys are doing real good work down there. When he puts the motor together right will he be allowed to use all caps on "blasto"?
Maybe, we will discuss this tonight.
wait a minute...was i supposed to put that brass tubie thing back onto the crank?
really?
shit.
Man, never gets caps at this rate.
Justin, you amaze me sometimes. I hope it's something as cool as no ATF.
tom reread to see how silly he is.
i know i read it. pretty awesome.
i will figure it out/.
