Well, the needle that came in my clone is quite a bit longer than a genuine needle, but the indexes for the clip are much lower; if that makes sense. It's about the same size as a genuine W7, but when you actually put the clip in it and run it, it ends up sitting a bit higher (richer) than a W7 in my clone. I don't even know why I tried running a genuine needle, probably thought "hmm, genuine, must be good". This was incorrect. My problem was I could go WOT for maybe 1 or 2 blocks before it lost all power. I never soft seized, I don't think, because the cylinder and piston looked fine, even after I fixed the problem and blasted with it for another few hundred miles.
With the clone needle, I ran a 70-something jet. With the genuine needle, I was at a 90-something jet, that's how lean it made everything. I just thought my port job sucked fuel until I looked at it. There wasn't anything wrong with anything, they just weren't compatible, it turns out.
But, like I said (wasn't clear on this bit), when I stuck the original clone needle back in, I could jet it like a normal human being, and it ran stupidly fast.
Probably not the problem you're having though, it's just inspiration.
