New Engine Build for 103
Upon many words of advice, clean and store the stock motor and build a new one. IF any of you out there have done this before, I'd like to know the complete setup that you used.....
Thanks
Baja
Re: New Engine Build for 103
Depends on what you are trying to do. If you want mega speed possibly, but there is a lot you can do to the stock motor. Also if you are talking about the bat, you might run into trouble if you try to varriate it.
It is the Bat.....it pivots ab out 30 degress up and down with the throttle....thinking I may opt for a head/piston kit, PHBG carb and a pipe for starters.....it's alot of cash and if I don't get the desired result then why dump the money into the CDI, suspension, etc?...
