Does anyone know where to find Dellorto jets near Chicago?
I bought an HKMOTOs 15mm carb and need to find out if other jets work because I am unable to find a straight answer on the interweb. Thank you.
I'm 99.9% sure that dellorto jets work. Buy one from treats and give it a shot.
Thank you.
Should I get the 5mm or 6mm jets? Also, can I measure this to see what I have in my carb? How?
And what jet should I have if I have this 15mm carb with air filter and gutted stock exhaust?
Anyone else have any input?
it's the standard 5mm jet, the 6mm are for tomos. probably in the sixty range, but not sure of that.
I thought I had read somewhere that SHA clones don't take dellorto jets. That may be a different manufacturer though.
measure the jet, take a standard m6 bolt and try to thread it into the jet holder if it fits you have a 6mm jet, if the bolt is too big then you have 5mm
