Break Wiki
I think somone that is a break master should post a wiki on how to make your stock break shoes and drums work better...im just sayen.
Re: Break Wiki
I would, but I'd probably brake the wiki.
Re: Break Wiki
Rob @t ATTN! Burrito /
diks breaks
Re: Break Wiki
check out the brake pulley on a columbia I used to ride... really worked well.
Re: Break Wiki
hmmm thats pretty interesting... so you only get half the pull but it would be twice the force right?
Re: Break Wiki
worked really well you just had to adjust it well. I gave this columbia to my daughter so it had to stop well or it was going to the back of my garage forever as columbias never had good brakes.
Re: Break Wiki
Re: Break Wiki
Conrad Conrad /
good one Saabsonettguy ;)
Re: Break Wiki
I'll wikify anything that anyone wants wikified.
Break Wiki
one cool trick is to thicken the thing that twists between the shoes to push them out. cut out two rectangular pieces of sheet metal, cram them in there and put the wheel back together to make sure they fit w/ out making the brake rub, if they do, jb weld them on and enjoy a little bit more stoppiness.
Re: Break Wiki
anyone ever try doing a mechanical foot break for the rear like motorcycles?
Re: Break Wiki
Why bother? some peds have rear breaks that are operated by back pedaling like on a cruiser bike.
Re: Break Wiki
It's really simple to make brakes operate like they should.
First of all, check your drum. It should be within the service manual limits. If it isn't it's never going to brake well. It should be clean and rust free. If it's rusty, sand it with some 400 grid (or so) sandpaper till it's smooth. Only sand lightly in the rolling direction of the drum.
Clean the drums out with brake cleaner and some paper towels.
Sand off the edges of the shoes, so they are ramped instead of straight. This really helps even grabbing. Sand the rest of the shoes diagonal.
Clean the brake plates with brake cleaner. Make sure the pivot point isn't rusty or stuck, if it is, fix it. Lubricate the pivot point with some bearing grease, Not too much, you don't want it to drip off.
Clean your hands and then install the shoes. Clean the shoes with brake cleaner, because the sanding dust and your fingerprints will be on em.
Install into the drum, set the cable as tight as possible without the brake starting to drag. Use good, well lubricated moped or motorcycle brake cables. Bicycle cables stretch, so they suck for moped brakes.
That's all there is to it. Well maybe that you should use NOS brake shoes if you can get them. Or anything OE. The cheap knock-offs are usually crap.
