wiring without battery
Hi, looking for some advice on doing a rewire for a custom Honda Chaly70.
Im only running lights and brake light and want to create a simple wiring circuit.
Does anyone know if I can use the single yellow output wire to a voltage rectifier and without the need for a battery. Or do the Honda coils need a constant load on them (eg battery, or lights on permanently etc)
p.s. its a 1972 6v
Thanks
Re: wiring without battery
I'm not familiar with the model of your bike, but unless the headlight/brake lights are DC only, get rid of your battery and rectifier all together.
A rectifier simply turns AC into DC voltage.
The only problem is, you're going to need to install 12v bulbs. The battery acts as a voltage regulator and prevents bulbs from blowing. Without it, your voltage will likely spike above 6v and fry some bulbs up.
Split your yellow wire to head and tail light, and run wires BACK for your grounds to the main ground. I have found that Hondas NEED the ground wire running back to offer more resistance to the circuit compared to light mounted grounds, to prevent the blowing of bulbs when you remove the battery.
Whereever the battery currently is in the circuit, you can just jumper it off and remove it as well as the rectifier.
Hope this helps!
Thanks Stacy
I have found a company who supplies 6v regulators (one wire in, one wire out)
So i think i will try this method, hopefully it should prevent the bulbs from blowing. Where should I run the ground wire back to?
Thanks
Lee
