bigger carb on my qt50
hey what size carb do i want to move up to on my stock qt 50 and what els should i do to have it perform smoothly?
Re: bigger carb on my qt50
any help?
SHA 15.15 fits on it without the shim.
exactly what the man above me said. It proved to work great on a friends qt-50
Mikuni VM18-144. Slide a piece of PVC pipe over the intake manifold as an adapter. It's either 3/4" PVC or 1" PVC. One of those two is the exact size. Just cut it to length and you are good to go.
if im doing this to the carb am i going to have to do somthing with the exhust bc is bringing more stuff in at a faster rate is my exhaust going to have to handle pushing stuff out faster or is this not going to hold me back?
I run the Mikuni 18 as well. You get them on Ebay for cheap and they are easy to tune and real reliable. I didnt have to do any jetting, it runs good (stock QT50)
I used rubber for around the intake but am going to upgrade to the PVC...never thought of that.
about a 70 $ price range for that carb or should i be searching for something cheaper?
i would get an expansion chamber if your bike doesn't have one yet. then up jet. ian expansion chamber is the biggest gain in 2 stroke motors other than not running right to running right.
