got this from treats
puch 70cc 45mm reed valve kit
With
polini PHBG 19mm - 21mm reed block intake
It hits the magnum frame, and also its at a really weird angle
How do you make it work?
With
oh dear, you didnt read the fine print. You gonna have to fabricate your own intake on that. Why dont you see if you can sent it back and get the treats 70cc piston port and a manifold. There is no bolt up solution to this unless you can find one of those nutty manifolds some dudes were making here -
that kit really doesnt claim to be bolt on. Its a kinda bolt on... its really a tomos reed kit with a flat exhuast port so you can run a puch exhuast.
