With 16x36 gears, I can go faster, but it takes more road to get there, and with the brakes on this moped, hmm...
The powerdynamo ignition does not have a curve, and I have it set where I don't hear any pinging at any RPM, so this may be a little retarded at high RPM? Is this correct?
What I was really getting at, is that I'm not supposed to be going more than 35MPH anyway, and I'm willing to sacrifice some top speed for better acceleration. I'd like to keep the gearing about where it is, but get a pipe that will maybe widen the powerband a little, and move it to a lower RPM range.
I could get a bigger rear sprocket, but I don't want the engine screaming at 30MPH. I just want to be able to cruise around 30-35MPH, and have lots of power. If the powerband hit at 25MPH, I'd be happier, even if I max out at 40-45MPH. I can hack and weld a pipe if I have to, but is there any problem using a Proma GP or something like that?
Thanks for the help so far. Thanks for the input on the timing Zacko, I don't think I've got that perfect yet either.
