trying to fit the tecno boss exhaust on my maxi and nothing seems to match up right. none of the holes line up and im not sure if its worth trying to fix or just getting a different brand. any ideas?
perseverance!
HATEBREED
I have had to take a dremel and widen the holes on the header as well as open the hole on the rear flange. That's what your going to need to do.
- Joe
I've had to open up the holes on the flange on every single performance pipe I've ever put on a moped. If the holes don't line up, I usually use a bracket from the hardware store (like a piece of metal with holes in it) to make everything line up.
