Tomos Jet
i bought an estoril for my 95 tomos A35 form treatland. i also bought a jet, a Dellorto main jets part #1486. however, it was too small to screw into my carb. obviously, its not the right part. any idea what i should be getting? and how big i should go? the only thing that isnt stock is the estoril.
Re: Tomos Jet
That should be the correct jet for your carb. Are you still running a stock dellorto carb? It is possible that treats could of accidently shipped you a different jet i guess. Make sure that you installing the jets correctly. If it is a problem on treats end you may want to order more jet sizes because 1 will not suffice, you need to try different sizes to ensure proper tuning.
Re: Tomos Jet
do u have an ecarwi carb?
Re: Tomos Jet
I doubt he does cause its a 95 with an A35 engine. Its unlikely.
Re: Tomos Jet
That should be right. You have the dellorto sha 14/12 correct?
Re: Tomos Jet
i think that's what i have, it looks like the deltoro diagrams i've seen online.
