also, as far as airleaks go, i sprayed starter fluid all over everything and it's pretty good. nothing happens anywhere, except if you really blast it by the exhaust flange it will slowly die. i'll fix that, the stud hole were close and i tighend them real tight, maybe it would sit more betterer if i filed out those hole a bit. and maybe a chunkier gasket.
it's my friends bike i'm tuning up. so i can't just go change shit and post more i'll bring this post back up when i'm on it again.
it's a sweet maxi, gunmetal grey powder coat frame, black pc forks and snoflakes. got a estoril on it. real clean/mean. mounted a longseat super low. made the mounts myself. it's like 1 inch off the fender. if you look at it from the side you can't see under it. he even pc'd the side rails. no chrome. all black and grey. i'll post a pic sooner or later.
