Re: tuning 20mm VM Mikuni carburetor
shaka /
Once you get the idle set at the proper RPM leave it. Sounds like you just need to lean out the mixture screw a bit. Adjust the mix till you get a nice resposive first 1/4 throttle snap. Then do some plug chops to see where your at. Just isolate each throttle position when doing the chops.
