Re: no start, malossi 62cc
Team AMERICA /
That worm gear assembly seals the crank case ...if you take the whole thing out, you expose the bottom end to a huge air leak and you will not get any intake of fuel ...put back the piece that the worm gear rides in and your block off plate and your motor should run ...its best to fill that tube with epoxy to take up case volume...
