I just finished port matching the case to this kit and the ports are a good deal bigger. As far as I remember the smaller airsal kit had almost the same size ports as the stock 2hp cylinder. The cylinder is very thin to fit the case but that should not be a problem, if nothing else probably better heat transfer...
