I need ported 50cc stock Puch port maps.
I want to see what people do with the different cylinders.
let me know which cylinder, and results with that set up.
Re: I need ported 50cc stock Puch port maps.
Hey Chris, the port map and indexing only shows where you can cut and port so you don't make a mistake. Index and map your own engine and see where you will cut. I hear you finally broke down and got a Tomos.
korado
low torgue cylinder raised the intake 1.7ish mm and widened slightly and it rips 42 all day.
Proma circuit with a drilled 12mm bing to 14mm 16x45 on an e50
raised EXHAUST
i raised the exhaust, didn't touch the intake. sorry if someone bricks a cylinder reading above
