70cc airsal kit
I have a 2000 tomos lx. the only new part is a biturbo exhaust and I want to get a 70cc airsal kit but I didn't know if I should get a bigger carb or a bigger jet
Re: 70cc airsal kit
Depends on how much $ you have.
I'd say, up jet while you break in the Airsal kit.
Save up $ to buy the 20mm Mukuni and intake that they sell on here.
Lose the biturbo, get something Quality.
Welcome to El Blasto
Re: 70cc airsal kit
okay, first off if you are running a stock carb you may want to get something bigger for your kit along with a intake to match. a bigger jet will be necessary also. look for a better pipe last probably v homoet 4p or a estroil.
Re: 70cc airsal kit
or you could run a myrons moped special and get it to 42 mph with only a biturbo and no upjetting
Re: 70cc airsal kit
skip the homoet and just go straight to the estoril.... great all around pipe.... using the stock carb, use a 70 jet and uni pod...... i was able to hit 45 with this setup ...
Re: 70cc airsal kit
where can I get a new intake from?
Re: 70cc airsal kit
treatland.tv
Re: 70cc airsal kit
I heard that the head from treatland leaks so im not sure whether its worth it.
