Basically what the title says. That's what I'm doing and I'm having trouble. I just got this dellorto and manifold from treats, and I'm instantly lost on how to install it. the manifold wont even fit into the carb. Mostly just wondering why that is when I bought them together. Also, it seems like everything is going to be backwards to a way that's convenient (as in idle screw will be on the other side, where it's difficult to access, fuel line will have to loop around carb etc). That's not a big deal, I can work with it, I just wasn't expecting it.
I know these things aren't designed for E50 engines, but I was led to believe it should work. And besides, most of m issue is with the manifold/carb not agreeing. Can anyone explain what I'm supposed to do about this? I was so excited about this change from bing to dellorto, and now I'm at a standstill.
I know the answer is going to be absurdly simple, but I still really appreciate it. Thank you.
