za50 carb mount threading removable?
† CH∆D † /
Im trying to make a riser for my 15mm intake. Figured out how, but now I realize the stock "what should be bolts" are threaded into the casing without a head. Can I just use pliers etc to get them out & use a longer bolt to handle my riser?
I hope its clear enough to grasp. Not to good with my wordzezez.
Thanks.
Chad
Re: za50 carb mount threading removable?
Use 2 nuts and lock them together on the stud you wish to remove. As in loosen bottom one and tighten the top one so they come together. Then just put a wrench on the lower one and back out the stud.
Yep. And do the reverse of this to put new ones in. Tighten the top nut to screw em in.
† CH∆D † /
K Ive tried this. I got the uber tight & it wouldnt back out.
Were these formed into the cases? Or tapped in? Im taking it to our local fastener shop right now to see if they can help.
Uhuh.
Chad
They were tapped in. Hit it with a little WD40 and try again. If that doesn't work, go to Sears and get a stud puller.
