does anybody know if a dio/elite performance variator will mount to a pa50II crank? i can't find the dimensions of the tjt vario to compare.
here's what i'm thinking:
I really doubt it would bolt right up or someone would probably have done it by now. If you are a crazy fabbin madman I would say DO IT!
says 20mm diameter. just measure your clutch bell and find out.
I think noogie posted the i.d. of the stock hobbit crank a while back. If not, camino-tuning.be.
No it wont fit . The bushing is too long , and the ID of the bushing is too small as well . If you are a wizard on the lathe you will be able yo make it fit . If not No chance .
That sounds like it should be fairly straightforward for someone with a machine shop. You mean to tell me NOBODY is doing this? Come on guys!
Suzuki Katana Vario is the one to machine. The Euros used to do it a bunch until the TJT appeared.
Also, if you have a machine shop you'd be better off machining a TJT or a Moby vario or something.
TJT, fuck a moby varoi on a hobbit.
Andy, Fred could probably make one work for you easily. But why? You already have a tjt. You would be cooler to make the back vario/clutch to mount up.
Did they ever bring those little Suzuki Katanas to America?
I have never seen one.
What all is involved in the swap.
I am curious.
what he said
