puch bing 15mm carb on sachs
word on the street is that the puch 15mm carb will fit on a balboa.
Just wondering if anyone could verify or throw some advice out.
Here is a link to the carb.
http://www.treatland.tv/bing-15mm-carburetor-puch-moped-p/bing-15-carburetor-puch-moped.htm
Cheers
Re: puch bing 15mm carb on sachs
Seen it done
If you have a c or d engine you can turn around the intake, match it, cut a small notch in one cooling fin on the cylinder, install the carb. done..
or tilt the bing
or make a spacer to raise the intake a little
or grind the bowl (not the best idea)
or all three of the above
as much as i hate the puch bing, i am about to put one on my sachs, i think.
rad.. its ordered. Will post the results
I think a dellorto would be a better idea, but what do I know.
Also german kids say the 15 amal arreches fit without any mods.
they are great carbs. i only hate them because they are expensive and the jets are expensive/way hard to get.
nerdzilla NoPeds :( /
whr the hell do you even find amal shit anyhoo?
Ϫ‡☄ಬ∞ ƀƖḬƝƊ ƤǂƿƎ ∞ಬ☄‡Ϫ - Hoke from Black Pipes Moped Gang /
i think a del 14:12 or 15:15 will fit with a riser and a beer can shim....
