mbk bidalot variator tuning
how many of you guys are running this? I have this on a doppler endurance crank, malossi 70, doppler clutch pulley, malossi x belt, doppler red spring.
The quality seems quite nice and works well, though with the heaviest weights, I'm still not fully variating. Others have this issue? I can't find weights for sale, but I think I can just stack them with a longer screw. The Doppler spring seems quite stiff, so heavy weights seem the way to go
Re: mbk bidalot variator tuning
try a different belt and see how that works. Something like a AX30 would be a good choice.
-naz
will first try heavier weights today, then if that's not good, try a different belt. the malossi x seems to work fine...the stock belt and stock replacement belt are too short and thin for this setup...and just not grippy enough.
stacked the weights (heaviest and lightest), works perfectly.
definitely got to a higher speed and variating more, maybe completely.
but seized before that happened. ha. will be back up and running by saturday (polini 70 replaces malossi 70)
jesus!
