Re: Building Up a Case
John /
Thanks, Jeremy. I wasn't so much planning on expanding the transfers -- I just wanted to make sure I understand it.
I'm going to try to do some port work on my extra stock cylinder. I will search for advice in other threads on this, but was hoping to understand more about what I will be getting into. The picture helps a lot in addition to your response. I guess the answer is, "It won't matter to you if all you're working on a stock cylinder." Maybe someone else could tell me I'm an idiot for bothering to enlarge the ports in the first place? I mostly just want to try is for experience's sake. Thanks again.
