Re: This one goes to 11
Lee Ving /
There are three different a35 ignitions...the only way to find out which one you have is to time it with a strobelight... if you are "off key way" then you have to verify what your degree is...Max...if you are talking about that 2 speed i eyeballed the timing on...carefull !!!! timing must be checked with strobelight and then set properly to take full advantage of what ignition you have ...or thrown in the trash if its the wrong one...the third one is a wonderful example of when things are made in india called a "FLASH"(obama ignition)...does not retard at 9-10,000...it just shuts off...Lets have a war...!!!!
