I use ram air on a 19phbg 70cc dr express. It loves it. I actually find that I can fine tune it (as per weather conditions) by changing the angle of the intake. I feel like I might have soft seized it once though in part because of the ram air. Basically, I was ripping in the upper 40's and went straight from WOT to closed all the way. I seized it right then and there. I think pretty much what happened is there was so much air being forced down its throat, but it was only getting idle jet fuel. I feel like this might have been part of the cause, but I was also running crappy oil in a kitted bike that was used to the good stuff.
I can tell you that when I had that set up jetting properly with a regular hi flow filter, I got up to about 44. The bent ram air filter added at least 3-4 mph and quite a bit of rpms to it. Honestly, at least in my set ups case, it almost feels like a turbocharger when the pipe hits then the air starts getting forced. That could be part of the crappy intake on expresses, having a sharper than 90 degree bend.
