Only does maybe 20 and it seems like it's reving out? 16 sha Parma and pipe any ideas?
tell us more.
That's about it runs fine plug little dark for breaking it in nothing really out of place I was thinking piston upside down but wasn't sure about the reving don't remember what jet but plug is good b7hs
mine didn't rev out till over 50!
that was even with the 15mm carb the low end was just crap. I would also get a 19or 21mm carb for that thing! you will never get it tuned right with that carb.
Mine runs out to 42ish with a 15:15 and stock pipe right now. Check your timing. My timing dropped my almost 90 degrees after the second ride. Easy fix.
Ok well turns out I need a new choke cable because my choke wasn't returning all the way, this is by far the fastest moped I own and I havn't even reved it out it just burst with power it's the first variated ped I own and I'm very happy! 80 bucks for a near mint le moped = greatness thanks guys
