Are intake and exhaust studs the same?
you gotta be more clear dude.
On a puch maxi 2 speed. Are they the same part? Interchangeable?
Yea, 6mm 4x. Good luck getting them out
Just use locking pliersto get them out and now use Allen head bolts to replace them
Allen heads are convenient but i dont like the idea of screwing and unscrewing bolts into the cylinder and risking stripping it out. What I did was just go to Lowes and by a pack of m6 1.00 bolts and use a socket and ratchet to bolt them in tight then cut the heads off. Cost all of $1.29. Then you have new studs and can use nuts again and just risk stripping the nuts and studs and not the cylinder when removing carb or exhaust.
You could always helicoil the cylinder, then use the allen head bolts, but $30 for the helicoil kit, and then the time and effort to do it right...
It's nice to have the helicoil kit around if you ever NEED it though.
