Hobbit Reed mm difference
I feel like somebody should have posted about this before, but I searched for a while and couldn't find any info:
treats has two versions of the boyeson carbon tech reeds, 0.3 mm and 0.4 mm, and I don't know which one I want. What's the difference in performance? They are both for modded/ported hobbits.
What's the difference between them and the old ones that weren't carbon?
Thanks, and again, I apologize if this has been asked before.
Re: Hobbit Reed mm difference
Thinner reeds are better at low rpms and thicker reeds are more resistant to fluttering at high rpm's.
Yeah !
Alex you need to put some dio 1000 over rpm springs in your clutch . Best 10 bucks you will ever spend . Whiplash low end !
