Re: EBR Forks
Sadder Joey P /
how did you put them on? the best way to install them is to tighten your headset bearings. then tighten the top cap, then tighten the two fork bolts on top, then tighten the bolts that tighten around the fork legs on the bottom triple tree. do this with the front wheel installed and all of the bolts on the forks loose. at-least it works for me.
