moby doppler er2 pulley
hey,
wonderin' does this pulley accept stock sprockets? if not, what sprockets will fit.
i just want a straight non-mangled pulley but, i'm guessing you need a doppler sprocket.
Jay
Re: moby doppler er2 pulley
since, i'll prob. need a 103 sprocket... anyone got a cheap spare?
Search is your friend, man.
Peugeot sprockets.
http://www.mopedarmy.com/forums/discuss/read.php?f=7&i=152633&t=152598
thanks ryan, i did search, though, that's why i was asking about the peugeot sprockets... quarterkick is out, that's why i was seeking other options here.
i've bought 2 different new replacement stock pulleys and both wobble due to the shaft hole and main drive rim being not in line with each other. looking at the other options
www.quarterkick.com has the sprockets you need. 11t is stock.
thanks jesse,
all the doppler sprockets come up as out of stock @ QK.
Mike McScoutington /
QK is updating the new site and getting all of their counts correct again. I think I may have bought the last Pug sprocket when I picked up the doppler pulley. It is a super nice pulley but be forewarned...It is sharp as hell. I sliced my hand on the edge of the pulley when I was putting the belt on. Most likely could have used about 3 stitches to put me back together, but a greasy shop rag kinda did the trick.
cool, how about the clips and such? will the stock be good or do you need a new set of shims and clips?
The stock should be ok as long as you dont mangle them all up when you pull them. I have the stock clips plus a .5 inch piece of pex tubing as a secondary shim to make sure everything sits where it should
beautiful pulley, btw, loving mine. you will not be disappointed..
