Are there reeds that will fit the 4p Polini reed block that I could replace? Or, is there a replacement reed block?
Mine are worn and no longer seal properly, I guess I would have to drill and tap the block.
Has anyone replaced theirs?
Drill and tap. Then you can use whatever reeds you want to begin with.
Thats kinda what I figured. Does anyone have pictures of this and reeds they used?
No pic. Sorry. Just a do it and go person. I can find out Monday what tap and screws I did use since the mechanic next door from where I work offered them up. It was an easy process, minus the grinding and clearence of the O-Ring base. Hahaha.
That would be cool thank you.
i have the polini reed block.
I put the boyeson dual reeds on it.
cut off originals, tapped new hole, screwed them in.
then from the inside i cut off the excess bolt sticking out.
from there i removed the little bolts and put locktite on them, them em back in the bike.
now im ripppppin
