Parma AV7...please clear some things up for me.
Motobee Goode /
Hey Le Tuners,
I just bolted a Parmakit AV7 setup to my beloved first ped, Penelope. Anyway, I just finished the majority of the bike, trouble shot some electrical, and started it up. After a short test run, I have a few fears that I would like to dispel before I do any serious blasting. I own a few mobys, but this is the most aggressive frenchie I have built other than a serious av10 build that is in the early stages of construction. That said, I want to make sure some of what's happening is typical and/or okay.
The setup:
-av7 Parmakit w/ stock head
-19 phbg
-points
-varplus w/ 6 med. weights (I think)
-ER1 pipe
The sources of concern:
1). The sound of the pipe has me freaked out. It sounds normal until I hit about 10 mph, then it sounds like pure death by chainsaw and it is 10 times more obnoxious than any other moped pipe I have heard. Also, after a few minutes of riding, there was some dark speckles of fuel around the ball joint and on the cylinder. This sounds and looks like an exhaust leak. Is that pipe just loud as fuck? Also, is the ball joint a necessary evil that will always leak slightly? By the way, I used a crush gasket and red locktite, and did not use that coupler thingy that came with the pipe (I just used the balljoint, hooks, and flange for hooks). I am hoping that that didn't dick it by leaving that coupler off. I will greatly appreciate any advice, encouragement, scolding, or tips.
2). My other concern involves the level of vibration I am experiencing. I probably haven't taken it over 35, but at about 20 it starts to vibrate like no other (like, arms start to fall asleep). I used Peter's urethane motor mounts which have always worked great on my stock bikes. However, I remember reading a post were someone was bitching about them causing vibration. Could that be it? Is this normal? Any input or troubleshooting tips?
Thanks in advance homies.
Re: Parma AV7...please clear some things up for me
They are stiff and can transfer vibration like solid motor mounts on 4x4 trucks.
everything you are experiencing is normal.
i'm running the parma and G3 pipe, it's loud as hell too... like LOUD! also, blows blackness all over the place with 4 springs instead of 2...
You think that's loud? put a clutch pulley on it. I feel like a dick riding it in my neighborhood after 5pm.
these pipes are super loud. try dampening the springs with a little gasket paper, too. theyre basicallly two little reverb tanks set up on your exhaust.
the urethane mounts arent soft like the stock moby rubber ones and will put your legs asleep below the knees i youre putting out enough rpms. go back to stock or try different rubber bushings if you want to get rid of that.
also, all mediums is probably way too heavy on a kit like that.
yeah, i feel like a total dick riding mine, too. all of jamaica plain knows and hates me. the phbg is a super loud carb, too, especially if youre using the bendy malossi filter. its basically a little gramophone horn to make youre already super loud av7 into the sonic equivalent of a 16-wheeler with no muffler and a bad fan belt.
Motobee Goode /
This is a relief. Thanks everyone. As far as the softer motor mounts, I was talking to someone a while back who was saying that 1977/Elliot/etc were using those tapered rubber plugs from the hardware store. Can anyone point me to a specific size or type?
Motobee Goode /
Haha, yeah, I am using the malossi grammophone as well.
you just get them at the hardware section. youll see the sizes that match up. theyre super cheap anyways.
try doubling up on the springs to cut out that racket.
''Loud pipes save lives''
I have ZERO issues blasting my neighborhoods.....
Louder the better.
My magnum is louder than my moby for sure!
Get some huge ass springs and replace the stock ones on that pipe. It quiets it right down.
