Re: Reed valve
Reveeen /
_pretty harmless material_
Ball bearings (like what is on your crankshaft) are what is called "zero clearance bearings", meaning: there is a very small amount of room between the balls, and the races, The introduction of ANY foreign material (that the bearing can't smash out of the way) into the bearing causes immediate failure. Reeds are not going to break off at low RPM, maybe your engine will stop before that bearing spins on the crank, or in the case, or maybe it won't.
Reed valves should be replaced @ rebuild time.
  Reed valveTopic by: Blue27343 Blue27343 06/11/09 06:44PM
  Re: Reed valveRe: Mo Peds Mo Peds 06/11/09 06:52PM
  Re: Reed valveRe: Reveeen Reveeen 06/11/09 10:06PM
  Re: Reed valveRe: Tate Tate 06/11/09 10:48PM
  Re: Reed valveRe: Reveeen Reveeen 06/12/09 10:09AM
