Yes, No?
Yes, No?
No I don't think so...
(copied from Treats) _puch 20 tooth front sprocket. specially produced for the people of treatland. You'll have to grind your case a little to get this to fit. or let your chain do the work, if you're dummy_
yes it will fit, but the chain wont
Shit. Thanks duders. Derek, did you figure out what youre bringing this weekend?
It takes a full 3 minutes with a grinder to make it fit. Also, you really can use your chain to finish the grind. Easy breezy.
will it fit on my one speed?
^ i heard it will fit e50, but you need to grind the case.
What rear sprocket are you planning on running with that?
Mine fit on a E50 with minimal grinding
I saw a 20x45 on an e50 recently. Why do that?
Thats not that big of a deal. I have a 18X40 set up right now. Almost the same.
That's my point... why not run 18x40 rather than 20x45?
because sprockes to fit on my pretty snowflakes are hard to come by. i'm currently running 18 to 45. and still have low end to spare. 70cc's is fun!
It wasn't on Snowflakes.
P.S. '77 has 40t's for snowflakes AND they work on the new slanty five Stars AND in a couple weeks they said they would be getting the 38 tooth with the same bolt pattern. Word to your mother.
