advange/disadvange between cast iron aluminum ?
What are the pros cons of using both types of cylinders?
Re: advange/disadvange between cast iron aluminum
Iron: super durable, can be overbored
Aluminum with / lining: 3 times the heat conduction of iron, lighter weight, usually a little more expensive. If the lining is damaged it cannot be overbored.
