So my new Pa-50 build as follows:
treat DR 70 kit
treat 21mm delorto and intake kit
proma cirtcut
so the bike starts up right away and idles perfect, running
on the stand it will rev so high, right away, it vibrates the
stand across the shop floor.
soon as I put the wheel down and try to give it about quarter throttle to drive away its like Bluuuuuuuuhh and I have to back out of it. If I leave the throttle cracked about an eighth
of the way it will slowly pick up speed and accept more and more throttle and after about 100 yards its goin weeeeeee
eeeeee and i'm doin like 40mph.
The carb came out of the package with a 90 jet and to be safe
I put in a 95 in case I was too lean for the new kit. Since then Ive put the 90 back in, then the 95 again, now ive
got a 100 in there and still cant get this thing to come on
from a dead stop. The jets I got from a yamaha shop
out of their jet assortment bin from under the counter,
they are shaped a little different but the threads are the
same and they dont touch the bowl. the guy said
they were molossi jets, does this matter?
So what do you think. Should I start changing the brass
metering rods? I've turned my mixture screw in and out so much I'm lost.
whats a good default setting for the mix screw? All the way in
then 1 3/4 turns out?
Dudes I'm close but still fucked. over
