What pipe have you used? Will the carb kit alone make a difference, or do you need to use everything together. Are the 19 PBGH or a 20mm Mikki carbs? What is kiting up with the reed. I didnt know the reeds were an issue? Can I leave the current ones alone? Sorry for the ignorance, I am new at this. I really appreciate your help.
What would I use the gunk or contact cleaner for?
