I'm looking to up both my top speed and acceleration on a fully stock Moby 50V. I'm considering a Ninja G3 pipe for the wider power band and regearing to add some torque. Any suggestions? Should I consider regearing for top speed and going for a pipe with more acceleration instead?
Pipes VS Gear ratios
Re: Pipes VS Gear ratios
Um, if you have a 50v you don't have gears, you have a variator.
Add the pipe then you want to tune your variator to get into your powerband quicker.
the g3 wont do much on the stock jug
duh, good call. I'm learning all this at work away from my bike. Sorry.
Would the G2 work better? If not, what's a good pipe that will add some performance now and leave room for further performance improvements down the line?
