Re: carb help please!!
kim jensen /
I read somewhere on here that the "hole" is an overflow on the carb if the float pin fails to stop the flow of fuel. Don't know why plugging it would make a dif.
Only your air intake and jet size would affect rich/lean ratio.
Although if you run low on fuel in the carb, you could run lean, but you usually stall out from lack of fuel before long.
kbj
  carb help please!!Topic by: jason jason 06/03/09 09:22PM
  Re: carb help please!!Re: jason jason 06/03/09 11:09PM
  Re: carb help please!!Re: kim jensen kim jensen 06/09/09 02:34AM
